View problems
On a particular project done by teamwork, if I open the file in the plan view it opens fine and all objects are visible. Once I go to view sets most of the objects dissapear.
I figured out a way to getthe objects back by saving the current view in the view sets. But is there a way around and why does this happen?
Thanks!
1 REPLY 1
Sounds like a wrong layer combination has been assigned to the view set. Verify that the view set is using the layer combination that you want and that you do not have a custom combination.
