Composite Structures dialog question
Using AC 8.1
When creating a composite structure (see attached image) I see that there is the concept of an internal line used to visually separate the different materials. These lines (in the image they are solid lines) can be toggled 'off' by highlighting the Solid Line in the composite window and then checking the Hide checkbox lower down on the form.
Is there any way to totally suppress the item 'Solid Line' from displaying inside the composite window?
Also, the help on what the exact differences between the Add Skin and Insert Skin buttons is rather skimpy. Does anyone have a clear description of when to use one vs. the other?
For those who are curious about my naming scheme, IWW4S2S5/8 translates to:
IW - interior wall
W -wood (S = steel stud)
4 - 4" nominal stud size
S2S - skinned two sides (S1S = skinned one side, S0S = skinned no sides)
5/8 - 5/8" thickness both sides (asymetrically skinned would be 1/2-5/8 )
Thanks
Alan
Petros Ioannou
Insert skin adds a copy of a skin next to the one selected and then you can make the appropriate adjustments.
Add skin , adds a similar skin (of the one selected) to the bottom of the stack. This way going from the middle of a composite outwards (to be more precise upwards) you can add skins symmetrically to the core of the composite.
HTH
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
