WALL WITH GAPS
Bling Keeta
Gaps in walls appear randomly. But if I move the walls out of the location, the gaps would disappear.
Any ideas? Thanks.
Ben Ling
B.L.LING ARCHITECT INC.
Vancouver, BC, Canada
Mac Pro 3.5 GHz 6-Core Intel Xeon E5
AC 20
Other walls on layers not visible that have higher intersection priorities!
And if those walls need to be in the hidden layer, then you can change the intersections priority number of the layers themselves (in the layer settings dialogue) so that the visible and hidden layer have different IP numbers.
Then they won't intersect with each other.
remember the IP numbers get save with the layer combination so you can have walls in one layer combination intersect and in another they won't.
Versions 6.5 to 26
MrC
Hi Bling could you send screen shot with all layers on?
ILIFFE ARCHITECTURAL
BRITISH COLUMBIA
macbook pro 2.7 GHz Intel Core i7 8 GB 1600 MHz DDR3 NVIDIA GeForce GT 650M 1024 MB
AC 21 USA (latest build)
