‎2015-03-14
01:10 AM
‎2023-05-24
08:51 AM
Rubia Torres
‎2015-03-14 02:36 AM
‎2015-03-14 02:57 AM
Steve wrote:
I was just going to post a topic asking about some similar things.
In your case, I am not sure I understand the questions very well.
#1- You can. If you select some walls you can select the Home Story you want it to be on.
#2 - You can. If you select one wall that is on Home Story only and another that is showing on All Relative Stories you can move move them both to a different story and change the display to what ever Show on Settings display you want.
#3 - I think your understanding of Relevant Stories is correct.
If you have a wall on one story and it extends up into another story, it can be displayed there too, but only so far as the cut plane for that story allows.
‎2015-03-14 03:19 AM
‎2015-03-14 03:23 AM
‎2015-03-14 03:31 AM
‎2015-03-14 03:33 AM
‎2015-03-14 03:35 AM
Steve wrote:
So here is my similar topic question you may be able to answer for me.
I am trying to make a roof plan in plan view for a two story house.
I can get the roofs to show up just fine because roofs have a setting for Show on All Stories. But walls only have a choice of Show on Relative or Home Story Only.
My problem is that my gutters are walls/complex profiles so I am having a problem finding a way to show the gutters on the first floor roofs in the same plan view as the gutters for the second floor roofs.
If I explode the gutters into morphs I can have them display on all levels.
Is there some there way to do this?
There ought to be some way to show walls and/or complex profiles on all levels.
‎2015-03-14 03:40 AM
‎2015-03-14 03:44 AM
