rob2218
WALLS - "Home Story only" and "All Relevant Stories"
three questions:
1. why can't we simply "select a story" where we want to see the wall?
2. Why is it that if there are walls with parameters such as "home story only" and other walls that have the parameter "All Relevant Stories"...and I do a CTRL-A while I have the wall tool active...why can I NOT move "ALL" the selected walls to the "Home Story Only" parameter?
3. Someone, please explain what does "Relevant Stories Only" mean?
I'm assuming that it means if a wall is 2 stories tall for example...and this parameter of "All relevant stories" is set...then you will see that wall on both it's home story AND the story where it extends up to? is this correct? Cause sometimes these walls don't behave as such.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
21 Replies 21
It is hard to say as I am not a programmer or product designer/manager.
But we can always submit wishes and let the developers know how the application would hep us the most.
DGSketcher
Legend
There is a poll in place for this issue...
http://archicad-talk.graphisoft.com/viewtopic.php?p=238783&highlight=show#238783
