WE not showing all menu options with imported profile
I have imported my profile from AC15 to AC16 and there are no menu options for the Modify Morph sub-menu under Design. I found some older posts saying that you pretty much have to use the standard default Command Layout Scheme, and start over with the menu and toolbar customization.
My question is can you add individual menu/toolbar items into my current profile, without starting over with the Command Layout Scheme?
thanks,
Jeff
4 Replies 4
Yes you can just add the new commands to your current profile, when editing the command layout schemes for either toolbars or menus you can filter to just show the new commands to add your your scheme.
That is the problem. Some of the new commands and menus are not showing up under the "new commands/menus" section. On my profile, they do not exist at all. If I switch to one of the standard profiles they show up. I am trying to see if there is a way to transfer some of the menus from the default profile to my profile without having to start over.
Check the show all commands alphabetically, they should show up there at least
Yes, the commands are there. I was hung up on the menu sub-folder itself. I made a sub-folder with the same name as the default, and placed it in the same location. I then manually moved the commands into that folder. There might be an easier way to do this, but I have the Morph commands that are shown on the youtube videos, so I am happy.
