‎2007-07-02 08:10 PM
‎2007-07-18 11:33 PM
Joseph wrote:No -- you can also set your parameters prior to placing the object.
Only after placement of grid Grid Element dialog has to be used to edit them all. Is this the only way editing after the fact?
‎2007-07-18 11:46 PM
‎2007-07-18 11:53 PM
Karl wrote:...and what happend to the "Grid System" menu?
(Note to anyone trying this tool for the first time: you must add it to your work environment in several places. Add to the toolbox, then for Tool Settings Dialog Boxes, enable all panels for the grid tool itself, and then in the Section and Elevation tools, enable the Grid Tool panel.)
‎2007-07-18 11:54 PM
Joseph wrote:That was not my experience with AC10 -- in AC11, however, I can't seem to find the Grid System...
I am setting Grid Element to my liking but Grid System Tool does not recognize it and uses some other default settings!?
‎2007-07-19 12:01 AM
Laura wrote:It is under Design menu. I had it working in AC10 but not AC11?Joseph wrote:That was not my experience with AC10 -- in AC11, however, I can't seem to find the Grid System...
‎2007-07-19 12:03 AM
Joseph wrote:Not on my system (see above).
‎2007-07-19 12:15 AM
‎2007-07-19 12:25 AM
Joseph wrote:Yes, I know this -- and I've adjusted my WE accordingly -- the "Grid System" menu is nowhere to be found.
If grid tool is in your Add-on folder it must be loaded, you have to look for it in your Work Environment to make it visible.
‎2007-07-19 12:39 AM
Laura wrote:Realy I am lost with this tool here is what I see..Joseph wrote:Yes, I know this -- and I've adjusted my WE accordingly -- the "Grid System" menu is nowhere to be found.
‎2007-07-19 12:41 AM
