WHEN IS GRID TOOL COMING???
matthewjj
Can anybody shed light on when the AC 11 grid tool will be available!!!
My team beta tested AC 11 and throughout the beta test the grid tool was available, albeit just as flawed as it was in 10. Then suddenly the tool was taken away from us when the final release came out. We were urged to used AC 11 on 'real' projects by graphisoft and so we did. We have real clients and we are working on a real $100m hotel and we need our grid tool back, asap.
*We have tried loading the RC1 grid tool but it doesn't get read by the final release.
matt johnson
archicad since 2004
imac 27, 4.2 GHz Intel i7, 16 GB RAM, radeon 575 4 GB, macOS 10.14.6
imac, 4.0ghz i7, 16gb ram, Radeon M9 390 2GB, OS X El Capitan
86 REPLIES 86
Laura Yanoviak
Joseph wrote:
Only after placement of grid Grid Element dialog has to be used to edit them all. Is this the only way editing after the fact?
No -- you can also set your parameters prior to placing the object.
But how? I am setting Grid Element to my liking but Grid System Tool does not recognize it and uses some other default settings!?
Thanks,
joseph
Laura Yanoviak
Karl wrote:
(Note to anyone trying this tool for the first time: you must add it to your work environment in several places. Add to the toolbox, then for Tool Settings Dialog Boxes, enable all panels for the grid tool itself, and then in the Section and Elevation tools, enable the Grid Tool panel.)
...and what happend to the "Grid System" menu?
Laura Yanoviak
That was not my experience with AC10 -- in AC11, however, I can't seem to find the Grid System...
It is under Design menu. I had it working in AC10 but not AC11?
Laura Yanoviak
Not on my system (see above).
If grid tool is in your Add-on folder it must be loaded, you have to look for it in your Work Environment to make it visible. I whish some one could help us to show the marker in Grid System Setting.
Laura Yanoviak
Yes, I know this -- and I've adjusted my WE accordingly -- the "Grid System" menu is nowhere to be found.
Realy I am lost with this tool here is what I see..
Laura Yanoviak
Perhaps there is a difference between the Mac and Windows installations???
