WINDOWS BETWEEN STOREYS IN ELEVATION
There must be something I'm missing!
I have a window on a stair, drawn on Storey = 0, which punches up into the storey above.
For some reason I can't get it to show correctly in the elevation. The wall on the next storey masks the top part of the window.
Setting the 'stacked windows' parameter doesn't seem to make any difference.
Can anyone help?
KEITH
Release 10 on Mac OSX 10.4
4 REPLIES 4
Djordje
Either put a hole in the upper wall where the top half of the window will fit, or do the multistorey wall.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
TomWaltz
Why do you have a separate wall on each story? A multi-story wall would solve the problem as well.
Tom Waltz
If you want to keep both walls (if, for example the upper wall needs its own window too) make the lower wall high enough to contain the window, and have the base of the upper wall at the top of the lower wall. Upper wall may then need to be Symbollic Cut, depending on Floor Plan Cut PLane
Thanks guys for these suggestions.
One of my colleagues had another method: he made the window oversized in the storey above, so that the space created in the wall accommodated the window from the floor below.
Of course this only works with 'stacked' windows (i.e. if there's no wall between the windows).
KEITH
Archicad 10 on Mac OS X 10.4
