Wall Accessories - Mouldings & Panels
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2005-05-19 02:23 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-05-25 02:39 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-05-25 02:46 AM
edit: Try to do a trim to roof to see if that will work for now. the SOE code is tricky
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-05-25 04:32 AM
FIXED:
--Moldings and panels now joint properly
--Connection work right now on Curve walls
The process is too complicated to explain here. I may as well post the revised version here for everyone to download.
Win 10, Archicad 19 INT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-05-25 05:33 PM
Matthew wrote:I tried it with a "Trim to Roof" wall, still no gable. I am fine for now using the object with the simple "+0.5" added to the ref_thickness in the Cutting Bodies section of the 3D Script that LiHigh recommended.
LiHigh wrote:So now that there are a few different people (non from GS) providing fixes to this part, which object is the on to use......?
Well, since GS never come to rescue, I guess I'll fix the bugs for our own sake!!!!!!!!
Thank you both LiHigh & Matthew.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-05-25 09:11 PM
Jay wrote:Hi Jay,
Both parts wors fine for me. We are between users trying to help each other, without GS help, so nothing is "official".
Each change on complex scripts like these ones, needs a lot of testing. Please, be indulgent. Try both, and select the best for you.
I can only thanks Matthew and LiHigh for their excellent work.
Still so much to do to have a "decent accessory".
Come on boys, keep on the good work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-05-29 03:54 PM
My workaround has been to temporarily "pull-back" the Intersecting walls before create the wall panel. This seems to work, but then sometimes after a regen of the Exterior section view the "cut-out" re-appear. I delete to accessory, pull walls back and recreate accessory.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-06-01 05:44 PM
I diligently recorded the bugs mentioned in this thread, but I beg you to please use the official channels (your ArchiCAD dealer) to report bugs. We sometimes drop in here for a little bug-hunting, but the only way to make sure bugs are corrected is to report them to your resellers.
Thanks,
Greg
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-06-03 08:16 AM
gkmethy wrote:May I also stress the point that you SHOULD send in the Bug reports when they rear their ugly heads? Fill in all the data required, especially waht happened before the crash, and send them ... they do go to the right place!
Dear Talkers,
Thanks,
Greg
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-06-05 04:28 PM
It seems to me that Mouldings and Panels accessory 'object' has a fundamental limitation that needs some re-thinking: more often than not I would like to use this tool to add skirtings ONLY. As far as I can tell, this is not an intuitive process because it seems that there is no 'option' to do this: one has to set other parameters to either very small dimensions or to zero!
Perhaps the genius code re-writers out there (including those at Graphisoft) could address this particular issue?
BTW I have taken up this matter with my re-seller during a recent visit - he took 10 minutes to find a workaround!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-06-09 11:20 PM
if thisOption were a boolean variable a script might look like this but with the correct variables set:
If thisOption=1 Then
parameters skirtings=1
parameters thisProfile=0
EndIf
and of course the appropriate code to change and hide values to get your goal accomplished would go in that and then the reverse code. Hope that help, i can provide a real example if you need it.
EDIT: I thought that perhaps i should add, that i have sent in a full report to Graphisoft concerning all the bugs listed within this thread, bugs found while i made and accessory based off of the moldings and panel accessory, and the wishes for a more dynamic interface.
-- Matthew Peychich
- « Previous
- Next »
- « Previous
- Next »
