‎2017-09-12
01:45 PM
‎2023-05-24
08:28 AM
Rubia Torres
‎2017-09-13 02:43 AM
‎2017-09-13 01:14 PM
"Barry Kelly" wrote:
Hello Jeffrey,
Unfortunately in section you will need to draw those crosses in manually.
‎2017-09-14 03:24 AM
‎2017-09-14 11:40 AM
Barry wrote:Since AC18, the same Building Materials don't merge within Profiles, so you can draw a rectangle, and split it twice diagonally to create the "X" in section - no need to change their Building Materials.
You can also create your own beam and column complex profiles by creating 4 triangular fills to form the cross.
The trick is to duplicate your fill and give it a new name as each adjacent fill must be different or they will simply merge back into one.
i.e. they must be the same fill but with different names.
But of course this means you must place each beam and column individually to form your frame.
‎2017-09-16 03:04 AM
