making slab finish continuous across few slabs
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2017-09-13
04:29 PM
- last edited on
2023-05-25
05:37 PM
by
Rubia Torres
2017-09-13
04:29 PM
All 3 slabs have the same finish.
I was expecting the floor plan to display it continuous,without the division line being displayed.
however, I get the division line, and I'm interested if there's a way for it to blend seamlessly.
I've got workarounds, (by using zones, or hiding the slab in floor plans; but I'm hoping for a "how it should be done" answer.
image in attachment;
3 REPLIES 3
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-09-13 05:14 PM
2017-09-13
05:14 PM
If you need the different composites, then I'll do the slabs without the finishing layer, and do another slab on top with only the finishing.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-09-14 03:49 AM
2017-09-14
03:49 AM
Lilith wrote:The plan is not a projected top view of the model - it is a symbolic view.
Also, the section seems to have no problem blending the different composite layers... so I'm even more intrgued why its a problem in top view.
In 3D (section/elevation) when similar surfaces join they will blend together.
But in plan you are getting a symbolic representation of each slab.
No joining unfortunately.
So you either need to use one slab for the entire area or at least for just the top surface or workaround by hiding them, or covering with white lines or fills.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-09-14 12:50 PM
2017-09-14
12:50 PM
To add to Barry's comment you can change the outline linetype & pen of a slab in the slab settings, so you could use a very sparse dotted line with a white pen to loose the edge in plan.
