Lilith wrote:
Also, the section seems to have no problem blending the different composite layers... so I'm even more intrgued why its a problem in top view.
The plan is not a projected top view of the model - it is a symbolic view.
In 3D (section/elevation) when similar surfaces join they will blend together.
But in plan you are getting a symbolic representation of each slab.
No joining unfortunately.
So you either need to use one slab for the entire area or at least for just the top surface or workaround by hiding them, or covering with white lines or fills.
