ā2019-09-28
09:01 PM
ā2023-05-24
08:10 AM
Rubia Torres
ā2019-09-28 09:11 PM
ā2019-09-29 06:45 PM
RandyC wrote:Yes, I have a foundation wall with a stone ledge and a stem wall that is 8" higher than the stone ledge. The upper wall with the stone is a complex profile with the stone veneer extending lower than the bottom of the wall. Should I create a separate wall or complex profile to create the stone that covers the band board? I don't want to model the stone with the foundation wall because on my foundation drawing I want the cut plane to cut though the stem wall only so that the stem wall only has the cut fill and the ledge shows up without the cut fill. I have attached a picture of what I am trying to achieve.
your lower block walls are higher than the bottom of the brick wall
ā2019-09-30 04:03 PM
ā2019-09-30 04:28 PM
