Andy Melaragno
Wall Connection Problem
Does anyone know how to fix the wall connection problem I have in the attached picture? I have tried to change the connection priority on both the foundation wall and the stone wall and nothing helps. The walls are all complex profiles.
Andy Melaragno
Columbus, Ohio USA
AC 24 - 27 USA | Windows 11 Pro | GeForce RTX 2060 Super | 32 GB |Intel i7-8700K @3.70 Ghz
4 Replies 4
RandyC
your lower block walls are higher than the bottom of the brick wall
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Andy Melaragno
Yes, I have a foundation wall with a stone ledge and a stem wall that is 8" higher than the stone ledge. The upper wall with the stone is a complex profile with the stone veneer extending lower than the bottom of the wall. Should I create a separate wall or complex profile to create the stone that covers the band board? I don't want to model the stone with the foundation wall because on my foundation drawing I want the cut plane to cut though the stem wall only so that the stem wall only has the cut fill and the ledge shows up without the cut fill. I have attached a picture of what I am trying to achieve.
Andy Melaragno
Columbus, Ohio USA
RandyC
You can space your stone wall 1" away from the foundation wall - then the two walls will not react with each other --
Andy Melaragno
Thanks!
Andy Melaragno
Columbus, Ohio USA
