2007-03-13 09:01 AM
2007-03-13 02:57 PM
2007-03-14 12:15 AM
Matthew wrote:Well its not that i can't connect them but there is no need to other than to form a closed reference line polygon for the zone boundary. In reality it will be built pretty much as it is drawn here - there is no need to 'build' something between the outside face of the glazed wall and the inner face of the concrete wall.
It seems that you understand the issues quite well. The bandaid trick you describe is the only one I can think of short of making the walls intersect or adjusting the zones manually. Honestly, I don't follow why you can't connect the reference lines.
2007-03-14 12:49 AM
2007-03-14 04:26 AM
2007-03-19 01:42 AM
2007-03-23 12:34 PM
owen wrote:
In the past I have just joined the gap with a simple line ('Zone Boundary' ticked) but im getting sick of all these 100mm bandaids everywhere - they are hard to maintain and they just don't feel right.
2007-03-23 11:13 PM
2007-03-24 12:35 AM
2007-03-24 06:55 PM
owen wrote:There are at least two (maybe more) area calculations built into the zone functions (within the GDL). The basic gross area calculation just shows the actual area bounded by the fill polygon with no deductions.
Using the Reference Line method the Gross area of the room comes out at 25m2![]()
What about that 1m2 Zone Boundary sitting in the middle of it?![]()
Net Area shows correctly at 22.04m2 - this measures to inner edge of all the walls. Why the hell does the Gross Area not recognize the riser walls? Does ArchiCAD think i didn't really mean it when i made them Zone Boundaries? Lets say this isn't a 5x5 room but a full floor apartment and that 1x1 riser is in fact a lift/stair core. Should it be included in the gross apartment area?
Is it meant to be this way or am i just doing something wrong?
