Wall Ends -- surfaces?
Geof Gainer
I can't seem to find where to change the surface color of a wall end to match the wall--thanks.
AC fan since v 7. Currently on AC 26 Build 5003 USA FULL, and AC 28 Build 3110 USA FULL, Apple Silicon,. 2022 Mac Studio, 32G ram. MacOS Ventura 13.7
Which one?
They are all a bit different.
The one that returns wall skins (Returned End) should pick them up automatically and you can't set any surfaces.
The others all seem to have a "Surface Override" in the parameters.
The Wall End tool places one of several (GDL) library 'well end' objects.  So, like any other object, you need to select the wall end and open the object settings dialog (cmd-T).  Surface is under the 3D Representation panel. 👍
Which one?
Ah: "Surface Override", missed it
