toofuerte
Wall Framing/ Accessories
I am trying to use the wall accessory to create a sips panel plan. when I try to put on the wall framing to a wall I get a messed up framed wall or I get the missing library part dot. I have tried it on a existing model in a project then started a new file and had only four walls and I get the same problem or it not showing up at all.
Gerald Acton "Gary"
Acton Design Services
Windows 10 PRO 64 bit
i7-5820K @ 3.30ghz 32GB Ram
Nvidia GeForce GTX 1650 4GB Ram
AC 19 - AC 28
4 Replies 4
Gerald
Hi I'm Steve
I have a wall framing add on I purched along with my ArchiCad v9
I have never used it like I thought I was....500.00
It's yours for 250.00 licences and all if you want.
Write me at mavrick533@hotmail.com.
I am in Southern Cal. with John Stebbins group.
Steve
TomWaltz
You're using the one that comes with Archicad, right? (not the CAOImage one?)
The dot can also mean that the object has an error in it and cannot display because of it. What parameters are you using for it? Are you getting any error reports?
Tom Waltz
toofuerte
well Yes, I am using the one in ArchiCAD, and I have tried several settings even not changing any from the default. and the other thing is it is working on some walls and not on others.
Gerald Acton "Gary"
AC 19 - AC 28
TomWaltz
Is there anything unique about the walls? Are they AC10 Profiled walls? Are they set to show on multiple stories?
Tom Waltz
