‎2006-11-21 12:42 AM
‎2006-11-24 02:00 PM
‎2006-11-24 02:58 PM
toofuerte wrote:You're using the one that comes with Archicad, right? (not the CAOImage one?)
I am trying to use the wall accessory to create a sips panel plan. when I try to put on the wall framing to a wall I get a messed up framed wall or I get the missing library part dot. I have tried it on a existing model in a project then started a new file and had only four walls and I get the same problem or it not showing up at all.
‎2006-11-24 04:20 PM
‎2006-11-24 04:42 PM
