Nick Darin Architect
Wall Join End Lineweight Issue
I am filleting two walls and cannot get the lineweight to continuously wrap the wall. I have tried changing the skins to the finish layer and that did not work. I have also set the wall ends to be on for both ends of the wall and have adjusted the pen weight. Still no luck. Any thoughts?
2 Replies 2
It is all to do with the composite skin end lines matching the skin lines.
This post may help ...
https://community.graphisoft.com/t5/Document-Visualize-forum/Wall-connection-and-line-pen-problem/m-...
That did the trick! Thank you very much!
