Wall Label
I'm trying to label my walls and am getting an extra arrow attached to the wall label symbol. How can I get rid of this?
4 Replies 4
1. Select the Label of the Wall.
2. Go to its Settings Dialog.
3. Go to the Symbol Label panel.
4. Check the Use symbol arrow checkbox.
5. Click OK, it should be good.
Thank you very much.
Odd that if you tell it to USE the symbol arrow, that it makes the arrow go away.
~scratching head~
~scratching head~
It means to use the arrow that is scripted within the symbol's GDL. Not to use the "tool's" default arrow. If you set the leader parameters to 0 in the parameter of the symbol, then it disappears. Kind of a misnomer.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
Thaank you very much.
