Wall Thickness greyed out (u r g e n t)
We´re working on a file produced in ac 6, then opened and saved in ac 9 before taking it to ac 10.
We are facing problems with adjusting the wall thickness for new walls; the wall thickness area is simply greyed out...
Most existing walls are still adjustable.
What may cause this, and is there a fix to it ?!
Thanks,
3 Replies 3
Fran_ois Chatelain
Hi Haavard,
wouldn't it be that you're using the polygon wall method to draw the new walls? Or maybe that the wall fill is set to a composite structure?
Cheers
Francois
François Chatelain
Worldwide Digital Imaging
Formerly posting as RanXerox
"A little bump will help blur your reflections"
TomWaltz
It's probably set to a composite wall type.
Tom Waltz
Thanks, that was it!
Just changed to a non composite wall and it works as usual
