Wall Trim
Does anyone know why the trim tool is acting like this? Is there something I can do to stop it?
Justin
10 REPLIES 10
Djordje
Wall extras?
Not much you can do, regretfully.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Yes, the wall extras. Thanks Djordje! I guess I'll just have to photoshop it out, right?
Link
You could probably use a Solid Element Operation to subtract it out, but if you'de like to upload a smalll module of it, maybe we could figure out exactly why it's happening?
Link.
Do you need the .pln file?
Justin
Aussie John
good old wall extras it seems. Sigh
Cheers John
[/size]
Link
It probably is 'just wall extras', but I'd still like to check it out for. Just select the elements in the immediate area, with all layers on, and go to File>External Content>Save Selection as Module. Then zip it up and upload it.
Link.
Ok, here is the file.
Um... Everything I just saved to a .mod file is now one object. How do I get it back to individual elements?
Justin
Link
Sorry - you must have had 'Change the Hotlink to the saved file' checked. Just go to Hotlink Manager and break the link. You may also have to ungroup them. Or you could just reopen the file without saving depending on what other work you've done since.
And your problem indeed looks like a wall extras bug. The only other thing I can think of is try maybe try reapplying them.
Link.
