Wall Veiwing problems
Ok how do I set up my parapet walls so that when looking at the floor plan of the above story their outline shows up but when looking at the RCP of the above story they don't show up at all.
The problem might be with the way I have my floor cuts set up because I assume that the problem would be solved if my RCP was showing things only above the cut line, but I can't figure out the story cut settings. Can anyone help??
Thanks.
1 Reply 1
Link
Forget the cut plane, just put it on a layer that is hidden in your RCP.
Link.
