Wall clean-up temperamental!
Interior walls not cleaning up at intersection with exterior walls upon returning to plan view since upgrading to AC 15? Have to constantly keep re-attaching all interior walls to exterior walls before publishing, major pain
5 Replies 5
Are you by any chance working in teamwork? I've had problems with our server (which only has 4GB RAM) processing some of our more complex teamwork buildings. The walls do exactly as you are explaining, they don't seem to clean up.
Not that I'm aware of, just individual project, only one instance open at a time.
Hmmm... not sure then. I don't see why upgrading to AC15 would mess with wall intersections, granted the material, reference lines, etc. haven't changed.
Our firm jumped from 11 to 15. We had to remake our template, favorites etc. Maybe something with that has caused it?
In that case, take a look at the wall intersection priority for the interior wall layer vs the exterior wall layer. Also, if interior and exterior use composites, check the priorities of the composite skins.
Two of lots of possibilities...
