Strawbale23
Wall closure in 3D
Hi everyone
Just wondering if there is a wall to "close" a composite wall in 3D. For example if I have an interior wall , plasterboard finish and insulation material interior layer, is there a way to close the ends of the wall with the plasterboard finish.
At the moment when I place an interior composite wall, in 3D we see all the layers at the ends of the wall.
thanks
AC26
https://www.zendsign.fr/
1 Solution
vistasp
Does the Wall End tool not work for you?
https://help.graphisoft.com/AC/26/INT/_AC26_Help/150_UserInterfaceToolSettings/150_UserInterfaceTool...
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Go to post
5 Replies 5
vistasp
= v i s t a s p =
bT Square Peg
spastor
Hi Strawbale23,
Try to use the "END WALL TOOL". If I undestand your question it doest just you are looking for.
spastor
Sorry vistasp, I din´t read your replay first, and post the same as yours.
Strawbale23
hallaluja! thank you. When was that introduced??
AC26
Lingwisyer
Guru
More than 10 years ago XD
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
