‎2021-07-27
11:28 AM
‎2023-05-19
10:36 PM
Gordana Radonic
‎2021-07-27 11:46 AM
‎2021-07-27 12:10 PM
‎2021-07-28 01:48 AM
‎2021-07-28 03:53 AM
Vincent wrote:I am not sure if you are aware of the wall accessories object that is available now.
Once my GDL skills get better i'll try to develop an object that can be associated to a wall and read its opening to avoid covering these area. Not sure if that's archivable but that'd be great for claddings and skirtings!
‎2021-07-28 08:59 AM
Barry wrote:Oh wow no I had no idea, that seems like a very interesting toolbox indeed! Barry I'll have to pay you some drinks for all the solution you keep providing me/us!Vincent wrote:I am not sure if you are aware of the wall accessories object that is available now.
You need to download and install the 'Goodies' and then load the 'Accessories' library that it installs in your Archicad program folder.
https://graphisoft.com/downloads/goodies
This accessory is not perfect but it does work.
It could also be used as a base for developing your own accessory object if you go down that path.
‎2021-07-31 03:05 PM
Architect | Graphisoft Certified BIM Manager
ArchiCAD 29 JPN/USA/INT | Windows 11
‎2021-08-03 03:03 AM
kmitotk wrote:Hi kmitotk, thanks for your feedback.
We also model all wall coverings as independent wall elements. We even model paint and wallpaper. The reason is that this way we can manage and organize all project materials using the Building Material properties, (all except for the materials in any Objects which are composed of Surfaces not Building Materials).
Modeling of wall coverings is actually not as hard as it may sound. Just turn off all layers except for the zone layer and then activate the wall tool and start inputting the covering by pressing down the space bar (cursor turns to magic wand) and click on the zone edges. We actually use this method to place floor finish and ceiling as well using the slab tool instead of the wall tool. Also, the placed wall covering can be duplicated in place and be edited and turned into a base, or a crown molding if you'd like.
The benefit of this method is that since all of these finish elements can be independent elements within the zone (or touching the zone boundary), they can be "related" to the zone which means that you can basically automate the interior finish schedule. Also, labeling the wall covering in the interior elevation will become much easier this way. You can also schedule the Building Material properties and create a project material specifications as well as automatic material index. The beauty of it is that if you set up everything right, all the material information in the drawing set can be in sync all the time; you change one material and everything regarding that material will update automatically, just like the way BIM is supposed be.
I've tried to use the Interior Wizard add-on mentioned but had to give it up because in addition to its limitations on the geometrical capabilities, the covering materials of the objects it creates can only be defined by the Surfaces, not BMats .
I wouldn't, however, recommend this method for a large scale project with hundreds of rooms though. I'm still hoping that Graphisoft will come up with better, scalable, practical and true to BIM material management solutions.
‎2021-08-03 01:29 PM
‎2021-08-04 08:43 AM
Problem is that the extend of zones depend from one place to another depending of the methods of calculation, and here in Melb they usually extend to external face of the walls or mid-wall for party walls.Zones normally extend to the mid-wall here in Japan as well, but rarely to the outer face though. When you place a zone, don't draw it manually but always use the reference line based method. The magic wand should pick up the wall outlines instead of the wall reference lines and the zone area calc will be based on the wall reference lines. And in case some of the surrounding walls can't intersect with one another and the zone won't detect the enclosed area, use a polyline to connect the wall ends to close the gap. Make a separate layer for the polyline so you can hide them on the floor plan. Hope it helps.
