Wall composites not showing
Im having a problem my wall composites are not showing, they just remain white when my fill is selected, could anybody explain why that may be? Thanks
I need to show the wall composites.
Check this settings:
Check you Model View Options Dialog.
Check to see if the Override Cut Fills checkbox is checked with the Show Skin Separator Lines checkbox unchecked.
That can cause such a display of composite Walls.
And please do not post a question in multiple forums.
I have merged the two topics and deleted your othere post with the exact same question.
Andro: I dont think those checkboxes have anything to do with the fact that he has a composite structure (if that is the case) but the skin separator lines are not visible.
