Wall contours around door;
Hello,
I dont know how to have neat wall endings around doors, I want to have same thickness of wall lines around door.
5 Replies 5
Steve Jepson
more than one possibility - but probably this.
You can turn those specific lines on or off for Composite Walls by checking a box in the Edit Skin and Line Structure dialog box. Right click on the Composite Wall - and select Edit Composite Selected/Profile...
All of them are turned on, is there another possible solution?
DGSketcher
Legend
It may be a local bug that needs looked at by your regional support. The attached is the equivalent drawing in AC22 UKI and the outer line pen does not return across the wall end.
My only other thought is the wall is a complex profile with the same name?
No its not complex profile, its composite wall.
What is also triggering me that it does same at wall endings, they are not closed with thick ouline.
Paul,
Check your on screen view options that you have true line weight selected and not bold cut lines
Regards
Scott
