Wall corner
I create wall boards, but how to do wall boards corner?
Please explain step by step.
Best regards,
nojaano
14 Replies 14
Use a tall slab, or you can use thin walls. If you use walls, make sure that they are on a different layer intersection group so they don't affect the actual walls of the structure.
Richard
AC26 (since AC6.0), Win10
...or a Complex Profile column.
Thank you!
I made a new wall, example width of 20 mm and 150 mm and I added a corner.
Is it correct?
Little problem, namely, the model space of one color, and elevation view another color, what is problem?
This looks perfect. Not seeing the issue you're having with color, though, and it's not clear what you think is incorrect. You should include your AC version, preferably in your signature.
Richard
Next step, and next question. How do you make such a roof?
And under the wall is this board (for water)?
David Maudlin
I would use the Roof Tool, then select the outside edge and set a custom angle for the edge of the waterboard.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David
Now is upgraded
David Maudlin
nojaano:
Thanks for adding the signature.
Another option for the waterboard is to create a Complex Profile with the Profile Manager, then use the Wall or Beam Tool to place the waterboards.
David
One question again:
Added a picture
