You will still need to check the overall height of your wall.
Adjusting the bottom height of the wall will lower the whole wall unless you have linked the top to a storey.
What you are seeing in the info box is the wall height and home offset.
Changing the home offset does not change the overall height of the wall.
Another option is to stretch the wall base in elevation or 3D view.
Then the top will stay where it is.
