nock_nagarkar
Wall end lines - how to get them to show up
hello!
I am looking into how to get walls to show up the way we like them to at our office as we transition to ArchiCAD, and am having trouble with the settings relating to the wall ends.
How can I get the lines to wrap the end up the wall, which a window is placed there? As you can see in the attached images, the wall ends on either side of the window is not showing the thick line
1 Reply 1
JeffH
Within your composite settings, make sure the check box is checked
Wall on top has that box checked   The wall on the bottom doesn't
AC24 / AC26 / AC27
Win10
