Zendrix
Only outer lines of complex wall
Hi!
I have a set of stone walls which are a complex profile (stone+plaster), but for this phase i would like it to show it as a single and simple wall, with only the exterior and interior cut lines, as in the picture.
I found a workaround by eliminating the lines from the complex profile menu, but for sure there a way to override those lines adding a new rule on the overrides tool, no?
Z
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
1 Solution
Florin Luca
Hi Zendrix, try  checking on Hide Skin Separators in the GO rules.
AC25-29 Solo US (latest build) – macOS Tahoe 26.4 – iMac Intel i7 | MacBookPro M5
Go to post
Florin Luca
Zendrix
Thank you so much!
Z
