2008-02-12
08:20 PM
2023-05-25
06:12 PM
Rubia Torres
2008-02-12 08:39 PM
2008-02-12 08:45 PM
2008-02-12 10:35 PM
2008-02-12 11:02 PM
2008-02-12 11:15 PM
Jesikuh123 wrote:You can dress up the symbol to get exactly the look you want
with using slabs though I am going to see all four outlines of the slab in plan- and it still own't look like a clean wrap right?
2008-02-12 11:19 PM
Jesikuh123 wrote:It looks like it's a bit different to mine. For clarity exactly which opening are you using? Maybe someone with the US library could experiment quickly.
In my library it gives me options: Turn in, Turn out, and Continuous.
Jesikuh123 wrote:As far as I know yes, unless you are cunning and fiddle with the GDL, one for every thickness of wall and opening width.
As for the custom doors, I would have to have a custom door for each type of wall I was putting them in right?
2008-02-12 11:21 PM
Jesikuh123 wrote:That would depend on how varied the conditions are.
2008-02-13 05:58 PM
2008-02-14 03:02 AM
Jesikuh123 wrote:There is a 2D (plan) symbol window in the library part editor. It is only minimally parametric - just a drawing that can stretch to match the size of the part. But for a one off it does the trick nicely, and for some simple parts or minimal size adjustments it can still work just fine.
And Mathew- how do you mean dress up the symbol? Which symbol?
