2023-11-07
12:44 PM
- last edited on
2023-11-11
12:25 AM
by
Solved! Go to Solution.
2023-11-11 12:35 AM
Place the Reference Line of the low height walls to the other side.
2023-11-07 02:05 PM - edited 2023-11-07 02:06 PM
You can try display order function to bring forward the high height wall above the low one,
Or to increase junction order value for the high wall height.
I hope that helps.
2023-11-07 02:35 PM
2023-11-07 03:31 PM
I don't have Archicad right now to try it, but you could try to change the Layer intersection of the low wall layer. I think it should work
2023-11-07 06:35 PM
I downloaded your file & tried my two tricks but no way, only the way @filipsuggested is the right one.
2023-11-11 12:35 AM
2023-11-20 08:07 AM
thanks
yes, we have manually tweak elements for reference line or split walls at junctions.
But there should not be requirement for any such manual adjustment. Archicad should show clean graphics as default settings with cut walls showing correct cut pen.
