jbArch
Wall materials won't align in the Render
Been pulling my hair out trying to get some wall textures to align... I am aware of the "Align 3D Texture" commands, and they seem to make things look right in the 3D model. But when I render it, alignment is shot.
In the attached view, there is a 1'-0" tall rim of siding (built with walls) which is the problem element. Tried this with a slab too, and get similarly bad results.
I'm working in AC10 on this project (only because I collaborate w/ someone who has that version) but could open in a later version if this is version specific.
Any suggestions? I've tried multiple textures too and get similar results.
thanks
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
4 Replies 4
silly question but why do do you not have the correct main wall just going down to the base.
instead of having two walls that dont line up ?
Ian
jbArch
Well, that's the workaround I ended up using. But the reason is that I'm trying to model it the same way it is built, which is with walls on platform framing. The 1' tall portion would be rim board and siding, while everything above is wood stud framing + siding.
cheers
NCornia
Graphisoft Alumni
Graphisoft Alumni
jbArch
Make the upper wall a complex profile with the siding extended down over the outside of the lower wall. That way you can still have the two walls as it is built.
HTH
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
jbArch
Nice, I like that better then my workaround. Will give it a shot.
cheers,
JB
