Wall on floor plan and section
Is there any way to set to wall different cut fills for floor plan and section?
For section I want white solid fill (or air space), but on floor plan I want black solid fill for better view.
5 Replies 5
You can set up different Model View Options to apply to your plan and section views.
OK, but it will aplly to all walls. I need it for several walls, not for all.
I can do that with different pen sets, but I think it is not absolutely convenient method.
Then you need to set different wall structures to different walls, by choosing different Cut Fills / Composite Structures
If you can give us a better idea of what is the situation and your intention, we may be more accurate with the answers. (screenshot perhaps)
Hope this helps
Nando Mogollon
Director @ BuilDigital
[email protected]
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Here is a screenshots. I have two wall types, interior walls with black cut fill (Wall 1), and exterior wall with composite structure (Wall 2).
I want "Wall 1" to appear on floor plan with black fill (as now is) but on sections - with white fill.
But for "Wall 2" I do not want any difference on plans and sections.
You will need to create Two different pen sets for that purpose,
Please follow the instructions on the image from top left to bottom right.
That will work.
Nando Mogollon
[email protected]
