Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Wall - representation on floor plan
muril00ng
Hi folks!
I made a column in a intermediate level (see the attached pic #1), between two stories. However, the column isn't showed in a original level, only on the stories above (see the attached pic #2).
How is the correct way to adjust the definitions of "Floor Plan Cut Plane" and "Floor Plan & Section" to represents the column correctly? I tried to study this contents but i need help.
Thanks!
#01
http://postimage.org/image/nv1rqyf8/
#02
http://postimage.org/image/nvdcidvo/
____________________________________
Murilo Noleto
http://www.kilobim.com.br/
AC 12 - 27 | Win 10 | 16GB | NVidia GTX 1050Ti | AMD Ryzen 7 1700X
Are you sure that the column is on the Story 0?
Seems to be on Story 1 with the setting for "Show on Stories= Home & One Story Up".
I have no problems with my column that has elevation 200cm from the Story 0.
muril00ng
Andro,
Actualy, that column i made with wall tool.
Both tools (wall and column) have the same problem in your representation.But, your help (using an object) resolves like a palliative. Later i will study this problems again.
Thank you very much.
Murilo Noleto
I would have thought setting the wall to All Relevant Stories should fix your display issues.
