Wall sheeting not showing roller door
I have a concrete dado with wall sheeting above. The wall sheeting is created with object cladding. The roller door works with the concrete but its not showing in the sheeting. How do I link the two together? How to get a hole in the object?
Cheers.
4 Replies 4
I think we need a little more information. Is the cladding you mention CadImage's Cladding tool? If you could post an image of the plan view of what your wall condition looks like it would help.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
I'd be guessing you have created this "concrete dado with sheeting above" wall out of two separate walls.
The roller door belongs to the concrete dado wall and therefore will not cut the sheeting wall.
You will need to add a separate empty opening to the sheeting wall.
But note there will be no automatic relationship between the roller door and this separate opening - their sizes and positions need to be adjusted individually.
Otherwise create a complex profile wall from the two separate walls.
Then it will behave as a single wall and the openings will work as you expect them to.
I have attached an image, hopefully that explains it better.
No, I dont have Cadimage, but I'll have to look into it.
Cheers. [/img]
Cheers. [/img]
Try attaching image again. Either use the "Choose File" button below where you type your message and browse to your image, or use a hyperlink to an image located elsewhere on the www.
