2018-06-14
08:19 PM
2023-05-23
02:12 PM
Rubia Torres
Solved! Go to Solution.
2018-06-15 04:57 AM
2018-06-15 03:39 AM
2018-06-15 04:36 AM
2018-06-15 04:57 AM
2018-06-15 05:41 PM
2018-06-29 04:22 PM
KrisM wrote:The see-through situation I am talking about is a cosmetic anomaly that you see, or don't see, in the 3D window depending on the view as you rotate. For example modeled trusses will show through a roof modeled as 5/8" plywood, even though there never was any sort of intersection. Rotate the view in the 3D window just right and you may not see it, or before you let you finger off the mouse in a rotation you wont see it. This does not show up in a rendering, but it does mess up your screen captures and looks bad or is distracting in live presentations. To get rid of this anomaly you can - for example - don't model the roof with Composites. Model the roof sheathing, 15# building felt, and roofing separately - just group roofs, in section copy-adjust for thickness, layers, elevation... you can leave a gap of 1/64" or something between the roofing and the building felt. You can use the Roof Surfacing Tool to put a standing seam metal roof on a "roof" and in the tool there is a place you can enter the gap between the roof you are using the roof accessory tool on. Sometimes moving a roof 1/128" vertical will do the job and will not show up in any dimensions. All a bunch of workarounds we should not need to make.
...Steve ... What might be the other ways to make this disappear?
2018-07-02 03:23 AM
2019-01-22 03:48 PM
