alex732
Wall thickness does not work in cm
Hello! I modify my dimension units in meters with 2 decimals and when i tried to draw a wall of 30 cm thickness, it does not change the thickness, even though I try to make it another thickness, like 20 ore 45 cm. Below are my wall settings.
Thanks!
Archicad26 Educational | Windows 11 AMD RYZEN 6000 9, GEFORCE RTX
1 Reply 1
Dialogues use 'Working Units', so it is 'Working Units' that you want to change.
'Dimension Units' are for the display of dimensions.
'Calculation Units' are what you see in schedules.
