We value your input!
Wall tool _ issue: "45 degrees cuts" for the bottom edges of the walls
tecsa
Hello everyone,
I'm recently facing the following "anomaly": the walls are having 45 degrees cuts at the bottom edges like in the bellow picture.
Can anybody tell me why? can anybody advise how to have normal edges (90 degrees edge) for the bottom edges of the walls?
PS: I'm using Archicad 21 (with usb key) if it counts.
Thank you!
Rares
Operating system used: Windows Windows 10 Enterprise
cuba
This is not normal, does this happen to all your walls?
It looks like a complex profile wall with bevelled edges.  Can you send more screenshots/infomation? walltype etc..
Apple M1 Max 32 GB Ventura
AC27
Yes, I noticed this issue for all the walls, independent on which level I'm creating the wall.
I didn't use complex profile walls.
The beveled edges are visible also on facades at the junction line between the levels of the building. Each time, the bottom edges of each wall are beveled (snips bellow) ...
Snip with basic section wall:
Snip from 1st level, having a composite section wall:
