Justme66308519
Wall
1. How do i change wall colour to just white?
2. How do i make line drawn using line tools thick?
3. How do i draw curved walls?
6 Replies 6
You keep posting beginner questions that are in the reference guide.  Please don't expect people here to teach you what you should learn by beginning with the basics.  Is the problem that there is not a User Guide available in a language that you are fluent in?
Some kind person will probably respond who has way more patience than me...
Justme66308519
Please sir where's the user guide?
Eduardo Rolon
See here:
https://help.graphisoft.com/AC/26/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC26_Help%2F001_ACHel...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Also have a look in the HELP menu.
You will find many links including an Archicad YouTube channel that has many informative videos on it.
Lingwisyer
Guru
Given these are beginner questions, why is the post labelled C++?
Good question, I have amended the labels.
I think (am hoping) it is just because a post requires a label, and that is what was set as default - although it is not in the list of available labels.
