We value your input!
Walls Dropping
mukster
Using Archicad 21 on a Mac platform. For some reason, the program is dropping walls at random 50'(15+ meters). I don't know why this is happening.
Are you creating the walls in the 3D window? The origin/working plane may need to be moved. If in 2D, what are your settings for the base reference level / offset and/or home story? Screenshot of your wall settings dialog?
One of the forum moderators
AC 28 USA and earlier   •   macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
mukster
Creating the walls in 2D in the view map. Not sure how to add screen shot to this format. Reference plane is zero
Check that the Gravity button is turned off.
Or maybe you have a height value in the 'Z' coordinate box (although this would not be random as everything would end up -50').
To add an image, click on the "Upload Attachment" tab just below where you create the post.
