Walls appear on plan but do not show in 3D?
Glenn Berger
I've drawn a group of complex walls. When viewing in 3D some walls not visible. I dragged a copy of all the walls to 50ft away and all walls showed. Then replaced the missing walls ( still there in plan view) with the duplicates. Problem solved. What is going on? I've reused the same file saved as for similar projects since archicad 10. Is this relevant?
Thanks the forum is always helpful.
Glenn Berger
Archicad 17, 24"Imac, second screen 24", 8g ram. OS 10.8.
User since 8.1
13 REPLIES 13
Check that you don't have two or more exact duplicate walls in exactly the same space.
These will show in plan but as the walls trim each other in 3D they may seem to disappear.
Use the "check for duplicates" add-on (goodie download from HELP menu) to check for all duplicates in you plan.
lukegolesh
Thanks Berry,
I have the same issue. I was hoping your fix would work, but I double checked the walls and none have a duplicate. This issue seems to occur with complex walls. I have never seen it occur otherwise. I don't want to assume it's a glitch in the software, but it seems to be. I'm hoping there is something I'm missing. I can pull the wall away from the corner and it appears (of course without a clean corner). When it is properly connected at the corner, the wall disappears. Thanks in advance to anyone who has a solution!
Archicad 24
macOS Catalina Version 10.15.5
Macbook Pro - 2.3 GHz 8-Core Intel Core i9
Graphics: AMD Radeon Pro 5500M 8 GB
Intel UHD Graphics 630 1536 MB
lukegolesh
Please ignore my first image- I did not intend to post it. Here are paired plan & 3D model views. The first is a clean corner where the wall disappears in 3D. The second pulls the wall and it shows up in 3D. Thanks again!
Archicad 24
lukegolesh
*Barry
Archicad 24
Lingwisyer
Guru
Is that window in the wall that is disappearing?
Ling.
lukegolesh wrote:
*Barry
That's OK, I have been called worse.
It seems to be an issue with the complex profile wall and the corner connection.
I have not seen it with a 90° connection, but I have had problems when the walls are at a very slight angle to each other - similar to the image you did not mean to post (right hand side).
It is very hard to guess what the problem is without seeing the file.
Maybe select the walls in plan, save selection as a MOD file, zip the file and attach it here.
There should be no need to share the whole file (at this stage at least).
I don't know if this is related (slightly different situation with complex profiles), but it seems there can be problems when the complex profiles get a little too complex.
The connection become so complex that some of the geometry starts disappearing.
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=70337
This can also occur when you have two walls overlapping, check to see if you have walls in an identical position even on a layer that is turned off
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Luke,
Thank you for the report and I am sorry about the issue!
I have come across this issue once, where the window was the one making the wall disappear. But in that case, the wall stood alone, no connection was made to any neighboring wall. Could you try to delete the window and see if it brings back the wall when the wall is connected properly?
Thank you very much!
Best regards,
MInh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
