Walls are not joining
auto-intersection is on but the walls are not joining at all where they meet. what other setting should i look for?
Please try to post in the correct section of the forum.
I have moved this topic.
Do the wall reference lines touch?
Is the layer intersection priority number (in the layer settings) zero by any chance?
Walls will not join if it is zero.
Otherwise can you show an image?
Erwin Edel
Make sure Clean Wall & Beam Intersections is still on. View > On-Screen View Options
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
