2021-01-11
06:38 PM
2023-05-09
03:46 PM
Rubia Torres
2021-01-12 03:03 AM
2021-01-12 03:06 AM
2021-01-12 02:43 PM
2021-01-13 02:37 AM
tsturm wrote:
This process of using building materials would require a lot of building materials and duplication of wall types. I do understand your suggestion. Thank you for the suggestion.
2021-01-15 06:06 PM
Barry wrote:yes. Yet that would mean making different building materials for Type X or Type C gypsum used for Fire Barriers that is different than for Walls which are not Fire Barriers such as Smoke Barriers. Both use the same Gypsum board yet you dont want them connecting.
You mentioned fire rated partition walls.
The composites for these wall types should have building material that are stronger than regular walls so they are not penetrated by the weaker walls.
2021-01-25 04:28 AM
tsturm wrote:
They should not blend with the demising wall of the unit. The demising wall has a 1 hour rating. The bathroom walls do not. Yet I would be using the same metal studs. I suppose I could make more building materials to use in my composites to help control the issue.
Would this be an easier method than using layer settings to control blending?
