VGDD
Hotlinks and Intersections
In the past with more complex projects I've done my steelwork design on a separate .pln and hotlinked it into my working drawings and vis-versa.
However, I've been working on less complex projects for a while but reverted to the above method for the first time on v.27 and it appears I now have to handle the hotlinks differently to previous versions.
Previously, when I hotlink for 'reference only' I put the 'hotlink master layer' on intersection 0 so it doesn't intersect with my live elements but this isn't working and I now have to select all my current projects steelwork layers and change them to 2 (from 1) to avoid losing them to building material intersection priorities.
Yes I know I should set my steel priority higher but in the past 0 has always worked. Has something changed does anyone know or any other methodology?
Archicad 11 - 27
Windows 11 Home
11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz 3.60 GHz
32.0 GB
0 Replies 0
