Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
SOLVED!
Walls missing in trace..
Llian
Didn't have this problem before but just today. The walls are not showing on the plans of the tracer. Please help. Thanks.
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
1 ACCEPTED SOLUTION
Solution
felcunha
Did you check the options in trace and reference palette to show your walls ? Open the trace palette, click on the right arrow beside the reference opacity slider and see if the walls are checked in...
Felipe Ribeiro Cunha
AC 26, macOS Monterey
2 REPLIES 2
Solution
felcunha
Llian
Thanks…that works!
