2020-01-20
06:04 PM
2023-05-09
04:17 PM
Rubia Torres
2020-01-20 10:42 PM
2020-01-20 11:13 PM
2020-01-21 02:32 AM
2020-01-21 04:27 PM
Steve wrote:Its a conceptual model for university. The walls only have to look right in height, thickness and in plan. I made the model you can see in my previous post in sketchup. I imported the sketchup file in Archicad and traced the borders from the sketchup file. I could also export from sketchup to dwg or pdf but I think the problem is that sketchup will always make the lines segmented as it doesn't create true circles.
As with everything in ArchiCAD, how you model it depends on what you need to do with it.
And of course, there is never only one way to skin a cat. I am assuming that the curved walls need to be documentable in terms of dimensions for radius centers, lengths of arcs, things like that - rather than just freeform ?
Are you making working drawings/plans for this, or is it just for a conceptual model?
Also, what is the source of the lines you want to follow with the walls? .pdf, image file, .dwg...?
Lot's of things will make a difference in how you model those curved Walls.
2020-01-21 07:26 PM
2020-01-21 08:47 PM
2020-01-22 11:41 PM
Steve wrote:Thanks for the reply, its 14.3 meters high with split levels, its a bit complicated
like this +/- a 6 story building ?
https://www.screencast.com/t/vVKT1vfVmkTY
2020-01-23 01:42 AM
2020-02-10 12:44 PM
